Trim around gear stick
Old Today | 01:55 AM
Bob Hornby's Avatar
Default Trim around gear stick
I have searched the forum for this topic with no results. My gearstick is often reluctant to move from Park to drive. I am concerned it may one day refuse altogether whilst away from home. I did find posts on this subject and the consensus seemed to be a problematic foot brake switch. Until I can get a mechanic to check this out, I need to know how to remove the trim around the gear stick so I can manually disengage the lock out should I need to.
Old Today | 06:03 AM
Big Koshka's Avatar
Take a plastic pry bar, similar to piece used to take cellphone screens off or to take off door cards.
Amazon Amazon
wedge it under the edge of plastic trim and pry it off carefully and evenly all around. this will take the trim off, but will leave piece around the shifter itself. If you need to remove that part, sorry, can't help you.
Once I had issue with shifter: I had to tighten two screws in front of the shifter under the trim, that i described how to remove.
Old Today | 06:48 AM
queensnewbie's Avatar
Correct, you just need to gently wedge a thin plastic pry tool under the trim piece and slowly work your way to lift the trim out of the notches, all the way around. It lifts right out and around the shifter without having to move any additional pieces. There are two screws that hold that piece of the console in place, left and right of the shifter in park, along with the two in the rear vents (if you need to continue to access below the trim).
bk000
May 14, 2023 12:11 AM
aeginc77
Mar 24, 2023 07:30 AM
Mclovin22
Nov 28, 2022 05:19 PM
barnsie
Feb 13, 2020 07:39 AM
NvmyJag
Feb 15, 2017 08:05 AM
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
