Replacement car battery advice please
Hello everyone,
The car I purchased is a 2017 F Type R coupe with 11,000 miles. The car has the original OEM battery. Its been attached to a battery maintainer for 9 years.
I want to change the battery.
Its my understanding that the OEM battery is VARTA or possibly FIAMM battery. Can anyone tell me where I can purchase either battery for the car?
I also believe that an Odyssey Performance AGM battery is equally good. Where may I find these name brand batteries at a good price? Or is there something else I should purchase ?
Battery should have 900 CCA power, yes ?
Thanks for the advice!
Hello everyone,
A couple of years ago now I replaced my 10+ year old battery with a "cheapy" (Century brand) that was on sale at my local auto parts store (Supercheap Auto) after making sure it met the above specs and it has never given me any problems. That said I religiously connect it up to a battery maintainer when ever the car is parked in the garage and I recommend you do the same.
A JLR battery from the dealer will last the longest, based on my experience but you’ll pay double for the pleasure. I recommend Interstate. I do not recommend Duralast. We go through hundreds of client boat batteries both marine starting and Minn Kota/Torqeedo EV setups including AGM’s. Boat owners install Autozone Duralast and Walmart because they are easy to run and get trying to save the weekend but then they call us for service when the three month old Duralast gets a bad cell or the Walmart just goes weak after a year.
I do recommend having the BMS reset after installing the new battery. Some folks here will say the BMS automatically adjusts to the new battery but best practices suggest otherwise.
My current one is Interstate, sourced from the dealer, as was its predecessor. I can't remember what was original because it got replaced under warranty, probably because it ran flat after the body shop scanned for codes and stayed that way for a while. It might have been Fiamm, but I'm not putting any money on my memory for that. The first replacement was before we all knew about the electronic insomnia that comes from many OBDC readers, including the two I currently have.
Interesting - I have read many articles that corroborate most of these batteries literally being built at the same facilities, but then again I imagine (like other consolidated manufacturers) they probably have QA/quality tiers that go under different brands (i.e. maybe Interstate or JLR batteries have a more strict criteria for acceptance).
