Jaguar xjs 1996, 4.0L AJ16 engine won't start
Hello,
This is my first time on this forum.I have a big problem.The engine dies while driving. After that, when trying to start it, all I could hear was a ticking sound from the pump relay and EGR valve. The starter turns the engine over, but it doesn't start, The technicians checked everything, but they didn't solve the problem.Has anyone had such a problem?
Please help me
Thank you very much
Please help me
Thank you very much
Kpetras,
As Greg has said, you either haven't got spark at the plug ends or fuel coming out of the injectors when the engine is cranking.
You mentioned that the technicians have "checked everything". But if they haven't told you which of the two conditions above aren't happening, then they clearly haven't checked the very basic 2 elements, That's very disappointing if they just haven't checked the obvious. It doesn't sound as if they don't really understand the XJS or it's electrical circuits.
I would start with some basic diagnosis in this order:
1. From ignition off, get someone to turn on the ignition to Pos II and listen to see if the fuel pump immediately starts buzzing. It will only run for about 2 seconds so be in the boot and able to listen for the pump IMMEDIATELY the ignition is turned on. If the pump runs briefly, go to Test 2. If the pump doesn't run for this short period of time when the ignition is turned on, then you have a fuel pump problem. It could be the relay or it could be the pump. Go to Test 3,
2. From Ignition Pos II, turn to Pos III to start the car, and check that then pump runs again whilst the starter is operating. If the pump doesn't now run, you possibly have an ecu signal problem.
3. If the pump didn't run in Test 1, check for voltage output from the fuel pump relay on Terminal 87 - the Blue & Red wire on the relay holder. If no voltage output when the ignition is immediately turned on, then check the rely mount in the holder. If it seems ok, check that there is voltage into the relay holder on Terminal 30 - the Brown & Red wire. If you see voltage in but not out, then change the relay. If you don't see voltage in (unlikely), that implies a failed input which is unusual. If you have voltage in and out on Term 30 & 87, then check for voltage at the wiring plug of the pump where it enters the tank (you need to strip the boot trim etc out of the boot. If you have voltage there but no pump running, then it sounds as if the pump has failed.
4. If you have the pump running on Ignition on and then again when the starter is operating, then pull a spark plug and conform that the plug is sparking when the starter is operating. If it doesn't, again you possibly have an ecu signal problem.
With the symptoms you described of the car just dying when driving and then not restarting, I wouldn't think it's a failed ecu. Far more likely to be something else such as a crank sensor.
Good luck, let us know how you get on. Don't change anything unless you've diagnosed that it's the problem. Otherwise, you'll be chasing shadows.
Paul
Paul
Thank you very much for your response.I'll try to explain in more detail what's in my car.When the ignition is turned to Pos 2, the fuel pump relay and EGR valve start to rattle.It means that the fuel pump relay and EGR valve are not turning on normally.They turn it on and then turn it off again.They seem to have weak voltage.The 12V voltage is good and the starter turns over perfectly, but the fuel pump does not work because the fuel pump relay is not working.Maybe it's an ECU problem?
Does it have 12v on Term 30 with Ignition on? What voltage does it have on Term 87 when it is cranking?
A failed ECU is not a common problem. Especially as the problem happened whilst you were driving.
Paul
Paul
Before you do ANYTHING else, check the Heated O2 sensor fuse.
I had what appeared to be the same problem in my 94 XJS 6.0 and could not find the problem.
This issue lasted me over 6 months until a Jaguar Master Mechanic went home and studied the wiring diagram.
Next morning he told me to check the fuse that was in the boot.
The fuse was dead, and the replaced fuse solved the issue.
I'm not even sure if the 4.0 has the same electrical components but you would save yourself a lot of replaced parts.
ALWAYS check the easiest/cheapest things first.
Good day everyone,
I am writing about the measurement results.
Pin 30 of the fuel pump relay receives 12V directly from the battery even without the ignition on. Pin 86 receives 12 V when the ignition is turned on..When the engine is cranked, pin 87 receives 3.0V (it should receive 12V).Between pin 85 and ground it shows voltage pulsation from 6.72V to 11.81V (in my opinion the resistance should be 0). My understanding is that there is a bad signal from ECU contact LI 189-19. What could influence the emergence of such a signal?
I have checked all the fuses and they are all good.
Good day everyone,
As I understand it, there are no other opinions, do I need to look for another ECU? Although when I open the ECU, I don't see any signs of corrosion.Do I need to look for exactly the same ECU, LHE 1410 DD or could it be some other last two letters? Or maybe try to repair it? Could you recommend someone who could do this in the UK?
I am waiting for any information.
Petras
Petras
Petras,
Before you condemn the ecu, I would:
- Confirm that you have a spark plug actually sparking when the engine is cranking. Remove a plug, earth it against the block and actually confirm it is sparking when the engine is cranked.
- Check the output signal from the ecu to the fuel pump relay is 12v from L189-19. Check it at the output pin of the ecu, not just at the relay.
Good luck
Paul
Good luck
Paul
Paul,
There is no spark in the spark plugs. Contact LI189-19 must give a negative signal for the fuel pump relay to operate. The 12V relay receives 86 contacts. It produces a pulsating voltage (6.7-11.8V), measured at pin 85 and pin LI189-19. The resistance between pin LI189-19 and pin 85 is zero.
Petras
Petras
I can offer one more guess.
When I first acquired my car, I experienced similar issues, one time it stalled out while I passed through a toll on the highway! I was finally awarded with a check engine light and code!!! It was the EGR Valve. I replaced it and it never happened again.
You can try removing the EGR and cleaning it up. Some people believe these things can be soaked in gasoline and cleaned, but I just replaced it entirely.
Petras,
That's the first time that you've mentioned that you don't have a spark at spark plug end when cranking. In which case, the problem is bigger than just the fuel pump relay circuit.
Did you ever do the tests to verify what is happening at the fuel pump relay when the ignition is first turned on before you start cranking the engine? Because at that point, the ecu is not dependent on things such as input signals from the crank sensor etc. So I think it's worth doing the test as I originally suggested to see if the pump does it's 2-second run on initial ignition on.
From my reading of the wiring diagram, it seems L189-19 gives a 12v signal to Fuel Pump Relay Term 86 when the key is on, rather than the Ground signal when the engine is running?
Paul
Paul
Hello Paul,
12V is supplied to pin 85 of the fuel pump relay, and ground is supplied to pin 86 from ECU pin LI189-19 when the ignition is turned on.The fuel pump itself is working, because I checked it directly. It's clear that there are more problems, but I think the ECU is to blame.Can you advise me on who can repair the ECU?
I'm not sure anyone has found someone that can reliably repair these ECUs. I think you should look on eBay for a new one. I worked with someone that thought they could do it in Florida. First attempt took weeks to get back. Didn't completely resolve the issue, the next attempt took months and was way worse. Had to swallow the money and call it quits. Forgot the name of the place, but after attempting a search, I don't think they're around anymore.
I'm sure other will want to know if you end up finding someone who can/will work on these ECUs.
Can we assume that you've swapped the relay, to rule that out?
There is also the EMS Power Relay to check, although since that also delivers power to the oxygen sensors, ignition coils, and other things, I would think it would wreak havoc on other systems, but still worth checking for 0 resistance at the ground wire (#85), and steady 12v with the key on.
