Valve Cover Gasket…Again?!
Old Jun 12, 2026 | 05:54 AM
Iconoclast's Avatar
Question Valve Cover Gasket…Again?!
2000 XJ8
An Indy tells me my driver side VCG needs replacement due to leak (I do have on & off oil leak spots in driveway.)
2.3 hr labor $494.50 for VCG set (He says cheaper to buy set ‘than piece together 1 side’) IDK that means.
Part $173.47
T wi tax $682.89
I ck my repair history notes & this will be the 4th time I replace VCG!
11-2009 @ 44,606 miles..did both VCG (Indy)
1-2011 ~ 50K miles Both VCGs (Jag Dealer)
5-2011 54,674 miles Passenger side oil leak VCG replaced under repair warranty by dealer
Now 100,100 miles 6/2026 I have driver side VCG leak.
Is this typical? So many times to do same repair?
Thanks,
Steve
Old Jun 12, 2026 | 09:08 AM
motorcarman's Avatar
15 years since gasket replacement does not seem abnormal.
Old Jun 12, 2026 | 11:05 AM
Jhartz's Avatar
Maybe just remove the offending cover; check ever spot on the old gasket, clean it it with WD40 or an equivalent, clean the mating surface, coat the gasket with a light coat of silicone, reinstall: do not over tighten.
Probably go another three years . . .
zonnie
Oct 2, 2025 05:25 PM
Marty McFly
Mar 29, 2025 08:27 AM
Catfan01
Dec 21, 2019 11:38 PM
94XJSOwner
Jan 22, 2009 06:53 PM
Dec 21, 2006 05:03 PM
