Valve cover gasket leak (f type r)
Old Sep 22, 2025 | 08:32 AM
zonnie's Avatar
Default Valve cover gasket leak (f type r)
My mechanic recently changed out the belts and got in deeper to confirm it was in fact a small valve cover leak on the passenger side.
The job is a bit too large for him.
I could only find one other thread on valve cover leak. Looks like a big job.
Anyone experience this problem? Are small leaks generally fine if you change oil regularly (5k miles) or is it something that should get addressed over the next year.
Welcome any thoughts or personal experiences you can share.
Old Sep 30, 2025 | 10:21 AM
CarlB's Avatar
Sounds like you have two things on your list now. Find a new mechanic and fix a VC leak.
Old Oct 2, 2025 | 05:25 PM
NBCat's Avatar
The most difficult part of replacing the cam cover gaskets is removing the fuel injectors. If not done correctly, the fuel injector can break and become stuck in its bore in the cylinder head.
Peter_of_Australia
44
Feb 4, 2024 10:42 PM
jampana
XF (X260)
Sep 24, 2021 08:57 AM
David Bedoya
Jan 15, 2017 04:12 PM
Axiom
Mar 1, 2015 02:02 PM
Jagxjs
Feb 2, 2013 11:36 AM
