Sights N Sounds Post all of your video and sounds clips here.
Fresh tune up (E-Type)
Old Feb 22, 2011 | 06:53 PM
ColtsJag's Avatar
Default Fresh tune up (E-Type)
got the new plugs and wires in today and shot a short video of the start up.
now just gotta rebuild the carbs
or maybe ill do some weber side draft carbs instead
http://www.youtube.com/watch?v=iXwaEACMumM
Old Feb 23, 2011 | 11:41 AM
What a nice looking E Type, sounds good too.
You are one lucky guy.
When are you going to take us out for a road trip in it?
Old Feb 23, 2011 | 09:05 PM
ColtsJag's Avatar
once i rebuild the carbs, replace the water pump seal and bleed the brakes
gonna see if i can take her up to the shop so i can use my lift. itll make working on it alot easier. not to mention ill have my tools in front of me.
also gotta re weld the exhaust
Old Feb 24, 2011 | 05:02 PM
You should probably have brakes before trying the road trip!
She does look and sound good though, a really nice car.
Old May 3, 2011 | 04:27 AM
Sean B's Avatar
The weber mod is popular in the UK, I have a set on a manifold if you fancy swapping your S.U. set - you'll need a higher pressure fuel pump like a Facet, and a fuel pressure regulator, or the back two cylinders foul, you get pressure differences between carbs.
It's a series 2 4.2?
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Nic1635
Oct 2, 2015 01:30 AM
jonahjob
Oct 1, 2015 07:54 AM
JagBrian
Oct 1, 2015 12:52 AM
