1968 Daimler 250 V8 Oil pressure issues
Old Mar 26, 2018 | 02:14 PM
Sprinterman's Avatar
Question 1968 Daimler 250 V8 Oil pressure issues
I have just bought this wonderful car but have an issue with the oil pressure reading. It is constantly 20psi, cold or hot. Is it the oil pressure relief valve? worn bearings (no noises)? faulty seal on pick-up pipe? oil sender unit? worn oil pump?
I am picking the car up this week. What do you suggest I do first? Fresh oil and new filter about 2000 miles ago - and still looking good.
I have a two post lift and am handy with a spanner. Where would you start first?
Any help would be gratefully received
Old Mar 27, 2018 | 04:17 AM
Welcome to the forum Sprinterman,
Jaguars and Daimlers have beautiful dashboards but they always went for style over accuracy. Gauges either stick in the same place or wave about!
First suspect has to be the gauge followed by the relief valve. If you had a mechanical issue restricting oil circulation, I'd expect noise. It's been several years since I had direct experience with this era models and members in MKI / MKII S type 240 340 & Daimler forum are likely to be of more help.
Old Mar 28, 2018 | 08:08 AM
Thank you for that nudge in the right direction. Can anyone suggest the best place to source parts for this oil pressure issue, specifically the pressure sender unit which people have been very critical about?
Old Mar 28, 2018 | 08:40 AM
The three main spares suppliers for early Jaguar/Daimler models are:
David Manners
S N G Barratt
S C Parts Group
A quick look at their catalogue shows S N G Barratt list the oil pressure sender.
mk1
Oct 21, 2019 01:47 PM
dstjohn
Aug 15, 2017 05:03 PM
dstjohn
May 3, 2016 07:25 PM
dstjohn
Nov 15, 2015 12:58 PM
Grant Francis
Oct 7, 2014 07:27 AM
