Jaguar Xj 351 dead
Old Mar 20, 2023 | 11:45 AM
Littlefoot2's Avatar
Default Jaguar Xj 351 dead
Hi all
My son has a problem with his car, Jaguar xj 351 diesel, all electric. 2011 model.
He explained to me that he got into the car, leaned over to the passenger side to get something while holding steering wheel and something at the steering wheel clicked.
He tried to start the car, he says it tried for a second then dashboard lights went off and the car is now dead, no power to the dashboard, nothing.
I am thinking firstly that he may have shorted something and a fuse has blown, or maybe hes done something to the
steering lock.
If its the latter then why would cause a power loss to the car.
Any info on sorting out this problem and where to start looking? car doors all open but the boot is locked.
Kind regards
Old Mar 21, 2023 | 05:07 AM
Steve M's Avatar
You need to post here; XJ ( X351 ) - Jaguar Forums - Jaguar Enthusiasts Forum
It is helpful if you put your location in your details.
Old Mar 21, 2023 | 10:23 AM
Smile
Thanks Steve.
I managed to fix my lads problem, it was a loose battery + connection.
I couldnt open the boot with the car being dead even with a donor battery connected to live and earth under the bonnet.
Had to remove the back seat unplug a inline connector and supply a live feed from donor battery + to the inline connector (the single pin male side) and battery - to a ground to open the boot.
Tightened up the battery + connection and the car came back to life.
Thanks again
Old Mar 22, 2023 | 03:54 AM
Steve M's Avatar
Well done.
Have you put your fix in the X351 forum, it could be useful to other owners?
Old Mar 23, 2023 | 08:49 AM
clubairth1's Avatar
Community Influencer
Good fix! Glad you knew about that plug under the rear seat too as it was a life saver here!
Also make sure the battery is not too old. Theses cars are picky about batteries!
jagtwit
General Tech Help
May 2, 2022 11:06 AM
Archi Bald
May 24, 2021 02:31 PM
agentorange
Feb 20, 2017 08:15 PM
agentorange
Feb 17, 2017 02:27 PM
RobertTheBloke
Nov 16, 2013 04:14 PM
