US Lower Atlantic NC SC FL GA
2012 XJL Portfolio AC
Old Sep 6, 2021 | 03:37 AM
vortac's Avatar
Default 2012 XJL Portfolio AC
2012 XJL Portfolio 70 k
Wondering if anyone has this issue or can add some thoughts Thanks in advance !!
. I would love to do this, but lately can't find the time
My vehicle is not blowing cold air at idle. If you get up to highway speeds it will blow cold. Took it to a local mechanic. He mentions they should be serviced at 50k I have 70k. He tried vac and recharge it did not help. Pressures on the low sign were approx 50 but would drop to what he stated was normal range 35-40 when the compressor kicked on, High side was approx 250, He stated the compressor was weak and changing compressor was the answer. I was unable to leave the car at the time. and still trying to find the time to get back. I was told by a friend to try a hose down the condense coil which I did and the AC seems to get cold at idle but did not last long. he said it might be the condenser coil
Mechanic wanted 1200 to change out the compressor
Pompa
May 27, 2021 12:20 PM
Malhur966
Aug 18, 2020 06:06 AM
KittyVet
May 31, 2020 11:57 AM
Enrico Spoletini
Aug 2, 2019 01:34 AM
