US Midwest IL, IN, IA, MI, MN, MO, OH, WI
Check Rear Lights
Old Jun 11, 2014 | 04:06 PM
ChrisArlint's Avatar
Question Check Rear Lights
I keep getting the check rear lights code on dash. but i have checked bulbs and wires and all is working. I also had a friend stand behind the car with the check rear lights was on and every light works my blinker my rear fog or whatever it's called and both left and right brake light and regular back lights work as well. and my reverse light works and the third brake light works as well i am stumped and have no clue. does anyone have any suggestions or have the same problem?
Old Jun 13, 2014 | 12:14 PM
mghirsch's Avatar
I would again check the bulbs, not to see if they are working, but rather to see that they are the same wattage. I would also check the grounds.
Old Jul 17, 2023 | 04:30 PM
Mlee007's Avatar
Default Same code
Getting the same code and was wondering if you were able to figure out the problem
thanks for any help
Old Jul 17, 2023 | 05:16 PM
thanks for any help
This is a 9 year old thread. Posting TECHNICAL questions in the REGION forum is not the best choice. You will get more help posting about the issue in the relevant MODEL forum.
Old Jul 18, 2023 | 02:53 PM
Hello
Yes I was able to fix this issue by replacing both lights. Come to find out that a bulb may not be out but puts out lower watts.
Pilotman11
Apr 26, 2016 08:02 PM
JayCee
Nov 26, 2015 07:07 AM
spanky
Oct 18, 2015 02:42 PM
newheart8
Jul 9, 2015 11:30 PM
ChrisArlint
Jul 10, 2014 10:26 PM
