US Midwest IL, IN, IA, MI, MN, MO, OH, WI
X 100 Code PO 171
Old Oct 24, 2023 | 08:46 AM
ss100jaguar's Avatar
Default X 100 Code PO 171
We are getting the above trouble code in a car where we recently replaced the timing chain assembly. The repair was done as a precaution, but the guides were beginning to crack. Since the repair the engine surges at idle. The code reads as a lean right bank. A smoke test showed no vacuum leaks. Overall performance is fine. The car is a low mileage 2001 with only 39K miles. It seems to me that the MAF sensor or throttle body would not cause a lean mixture on one bank. We have all the correct tools to keep the cams and crank in position. Any suggestions ?
Old Oct 24, 2023 | 08:57 AM
I recommend posting TECHNICAL questions in the relevant MODEL forum:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/
One of the major benefits of our forum is it's International. Apart from reaching a wider group of members with relevant knowledge in the Model forum, there's always someone awake and logged in somewhere around the World so you are likely to get a faster response.
Abe Mirza
Jul 19, 2023 08:53 AM
93xjs6cyl
Oct 18, 2022 05:08 PM
Paula Vecchiarelli
Oct 9, 2019 02:05 AM
WaterDragon
May 29, 2016 09:43 PM
maximum
Apr 7, 2014 04:12 PM
