US Northwest Washington/Oregon/Idaho & SW Canadians
Broken Stud Help!
Old Jul 6, 2019 | 07:17 PM
Artoman411's Avatar
Default Broken Stud Help!
Hello,
I need some help with extracting a broken bolt on my 98 XJR. I have zero experience with this and did as much as I could but would like more experienced hands to help. It's a small bolt on the coolant outlet pipe in the block. Bolt is sticking out from the block and not completely inside. Could anyone help? I'm located south of Seattle.
THANKS!
Old Jul 7, 2019 | 10:53 PM
CleverName's Avatar
Is this something that got cross threaded in? Or was it rusted and snapped off? What is the diameter of the bolt shaft?
Easy outs are the norm for extracting them, sadly I tend to do more damage than good with them.
Obviously some penetrating oil should be soaking the part right now.
Sorry I'm not able to help....
V
Old Jul 8, 2019 | 03:52 AM
The Region forum is a strange choice to post a technical question unless you are asking for a member to come to you and remove it?
The General Tech Help or X308 forums would get wider views and probably more replies from members familiar with the various techniques for broken bolt and stud removal.
Old Jul 8, 2019 | 09:00 AM
67ECoupe's Avatar
Go to Home Depot and buy a screw extractor set, and a universal tap handle and a small set of drill bits if you don't already have one. Also you might get an "Automatic Center Punch" while you are at it.
Also have your drill motor charged and ready to go, a pair of vice grip pliers and a can of a penetrating oil (many of us use WD-40).
See about generously soaking the area where the broken bolt is with the penetrating oil.
Let it penetrate for 10-15 minutes.
Then:
  1. If you can, grind or file off a flat spot on the tip of the extended bolt.
  2. Using your new center punch, see about making a nice little dent in the center of the broken bolt's newly formed flat spot.
  3. Using the correct sized drill for the screw extractor, drill a hole in the center of the broken bolt, going in at least 1/4-3/8" depth. And 1/2" is even better.
  4. Then with a light hammer, gently tap the screw extractor into the hole you just drilled.
  5. Using the Universal tap handle, see about carefully extracting the broken bolt with a counter-clockwise twisting motion while keeping pressure on the extraction bit.
  6. After you get enough of the bolt sticking out, you might try grabbing the extended part with a pair of vice grip pliers to finish taking the bolt out with.
Good Luck
Old Jul 8, 2019 | 01:16 PM
Brutal's Avatar
just use a Dremel with a small cutoff wheel , cut a slot in the top and take out with a screwdriver/ drilling on that small a bolt usually ends with more issues to fix
ragman1171
Feb 4, 2020 09:17 PM
JaguarXJ8L2005
Dec 2, 2017 06:42 PM
CookieMonster
Jun 13, 2017 05:32 PM
Fernando
Sep 16, 2016 10:26 AM
the beagle
Mar 30, 2015 10:49 PM
