US Western AK, CA, NV, OR, UT, HI, WA, ID
XJR needs help!!
Old May 4, 2011 | 05:42 PM
amha07's Avatar
Default XJR needs help!!
Hello guys, recently my 1998 XJR had a new fuel pump installed, but a check engine light with code 0302 was detected, which was misfire in cylinder 02. I really appreciate any technical advice I get on this trouble code.
thx
Old May 5, 2011 | 12:04 PM
jbm26's Avatar
Most commonly it is the direct ignition coil that has failed. Are your valve cover gaskets leaking?
Old May 15, 2011 | 11:19 AM
E36M3's Avatar
thx
Clear the code, swap the coil for cylinder #2 with another coil, drive the car until the check engine light comes back on and check if the code followed the coil.
That is a very easy way to tell if the problem is due to a coil.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
