Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
18" wheels
Old Nov 4, 2010 | 01:55 AM
Rockyf's Avatar
Default 18" wheels
can anyone tell me if an 18" - 8" width with 49 offset fit my 02 xtype sport.
the tires are 235/50 R 18 Conti Touring.
Will I get rubbing? Thanks.
Old Nov 4, 2010 | 05:24 PM
Rockyf's Avatar
I see it got move here. I have an Xtype 02 Sport Trim w/ mcpherson suspension. I currently have a 17" Sport wheels.
Old Nov 4, 2010 | 09:23 PM
Hey Rocky, I can't help specifically with your wheels on the X type, but, I had 17's on my X type and could have went to 18's no problem. Some guys here have 19's and there's even 1 or 2 with 20's !!!
You should be fine on 18's but you are correct and the offset is important, just make sure you get sumthin real close to what you have existing setup.
Do yourself a huge favour and check out an online tyre calculator...All you have to do is punch in the info and it'll pretty much tell you whats what.....If you currently have say 225 x 50 x 17 on the car and want to go to 18's.......you may need sumthin like 235 x 45 x 18 or similar.
As an example - on my A6 I've just upgraded from 225 x 50 x 17 tyre / wheel setup to 255 x 35 x 19.....Having checked it out the dia is within 0.61% or thereabouts which means the speedo will still be correct.
Hope that helps to point you in the right direction or at least gives you an idea
Old Nov 4, 2010 | 09:52 PM
Rockyf's Avatar
Thanks Jim. Called the guy selling the wheels & tires. He said just sold it.
Will definitely check out the calculator. Thanks again.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
