Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
offset?
Old Feb 28, 2011 | 03:37 PM
98xj8pro's Avatar
Default offset?
What is the factory offset for stock 99 xjr wheels. What happens if the offset of my new wheels does not match that of factory wheels. does it affect the vehicle much?
Old Feb 28, 2011 | 04:26 PM
plums's Avatar
A change in offset will affect your suspension and steering geometry.
A 0.25 inch change is probably not much to worry about.
Be aware that changing offsets will also affect tire clearance.
tirerack.com might have some FAQ articles and offset charts to help you.
BTW, if you change to a wider wheel/tire combination without changing offset, the geometry does not change. Tire clearance is another matter.
Old Mar 1, 2011 | 12:22 PM
SteveM's Avatar
Stock offset is 33.
Use this calculator to see what happens:
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Mar 3, 2011 | 04:15 PM
98xj8pro's Avatar
Thank you guys very much!!!
Forcedair1
Feb 19, 2020 01:51 PM
XJ8JR
Sep 29, 2015 06:59 PM
ferraripete
Sep 25, 2015 11:22 AM
DustysSon
Sep 13, 2015 04:17 AM
