Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
Snow Tires on XJR
Old Dec 10, 2010 | 07:49 AM
FirehawkMike's Avatar
Default Snow Tires on XJR
Bought a 2005 XJR the other day, and have not heard one good thing about the all season Perelli P6's on the factory 19" rims.
I can get a set of 18" rims fairly cheap, can I use Bridgestone Blizzaks in a 245/50/18 without an issue? If I reaseached correctly that should be a plus zero size. any experts can you confirm or advise before I make a purchase?
Old Dec 10, 2010 | 04:08 PM
Bump...
Old Dec 11, 2010 | 10:48 PM
does anyone have any thoughts or knowledge on this?
Old Dec 12, 2010 | 02:27 PM
jeffputts's Avatar
Mike Im in the same boat, Just bought an 04 XJR. From what I have researched, you need an 18x8.5" deep rim to clear the brembos, kinda a PITA to find, I thought about getting salvaged rims from car-part.com but for the amount id spend on 18" rims, I can just get some Blizzak's for the 19's for under $300/each mounted. those are 245/40/19
Let me know if you find anything different in your research
Jeff
Old Dec 12, 2010 | 10:40 PM
are rims from a regular 05 xj8 18 x 8.5? i can get a set of rims for under $500 and the tires would only cost me about $700
Old Dec 13, 2010 | 07:15 AM
jeffputts's Avatar
from what I have found no, they are only 18x8"
apparently the rims from the new XF will fit though
Old Dec 13, 2010 | 08:47 AM
are thoe 18x8.5?
Old Jun 19, 2011 | 11:36 AM
drcase's Avatar
I get why you can't go below 18" diameter, but why does the wheel width matter for clearing the brakes?
Matei Dima
Oct 8, 2015 11:45 AM
smith356
Oct 7, 2015 06:41 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
