Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
sticky aluminum wheels
Old Jul 4, 2010 | 11:57 AM
VandenPlass's Avatar
Default sticky aluminum wheels
is it a good idea to place a crown (very thin) of metal with holes between the disk (rotor?) and the aluminum's wheels ? Just preventing the whells sticking. I used the grey grease between the mag and the rotor but its a mess when I want to remove's one.
Old Jul 5, 2010 | 07:32 AM
Fraser Mitchell's Avatar
I would say don't use gray grease, use Coppaslip instead, you'll need less of it. I can't see how inserting a shim will give you an advantage, without a bit of Coppaslip, or grease, it will corrode and stick the wheel same as the disc/wheel on its own, surely ?
Old Jul 7, 2010 | 03:06 AM
As Fraser says, but don't put it on the rotor whatever you do! A thin smear on the hub contact surface to the wheel should help.
Usually when removing a stuck alloy wheel, I place the jack, crack all 5 nuts, remove 3, then raise the car a little of the ground. Slacken off the remaining 2, and if the wheel is stuck to the hub, a swift kick with the sole of my heel will break the seal.
Then finish raising the jack, and remove wheel.
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
xjrjag
Oct 24, 2024 03:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
DustysSon
Sep 13, 2015 04:17 AM
