Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
Would like to purchase 20" chrome wheels
Old May 22, 2013 | 09:45 AM
JagMan 98's Avatar
Default Would like to purchase 20" chrome wheels
I would like to purchase 4, 20 inch chrome rims for my XK8. I need 20x8.5, 5x120 wheels with an offset of 15-30mm.
Does anyone have some they would like to part with?
Is there a reputable dealer or website I should seek further info from?
Thanks!
Old May 22, 2013 | 02:34 PM
Michael Star's Avatar
Tirerack is always a good one to buy wheels from. How well are 20s and Detroit roads going to be together?
Old May 23, 2013 | 09:36 AM
JagMan 98's Avatar
Default Good Point!
Re-locating to Texas in September....
Old May 23, 2013 | 09:54 AM
Ah ok, that is much better then.
Try this site too:
Wheels - BigWheels.Net: custom wheels,chrome wheels,alloy wheels,car wheels,truck wheels,aftermarket wheels,large rims,wheel and tire packages,polished wheels
Old May 25, 2013 | 09:02 PM
Marsden's Avatar
Obviously you know what you're doing but FWIW the roads where I live are smooth as silk yet I'd trade my 19" Atlases in for 18" if I could. Just not enough rubber imho!
Old Dec 21, 2013 | 05:30 PM
richzak's Avatar
I own a 2009 Jaguar XKR Portfolio Edition convertible with the Alcon braking calipers. This is a special edition Jaguar where Jaguar USA only imported 200 of these cars into the USA in the convertible model.
I am looking to buy an aftermarket wheel for this Jaguar. I ordered the Conventry Whitley wheels and the front 20 x 8.5....5 x 108mm....center bore 63.4mm and an offset of +42 had proper fitment. However the rear 20 x 10....5 x 108mm..center bore 63.4mm and an offset of +25 rubbed against the brake caliper slightly.
My question is.......in order for the rear wheel to have proper fitment, I understand that I would need to go to an ET+20 for the wheel NOT to rub against the Alcon brake caliper. Is this correct? Can anyone confirm this?
I have found, I can order a Lexani wheel where Lexani drills the bolt pattern 5 x 108mm and then machines the offset for proper fitment.
I just want to make sure that a ET+20 is what I need to clear the braker caliper since the ET+25 would not on the Coventry Whitley wheel. Do I also need to know the backspacing?
Can anybody help provide this info?
Thanks in advance for your response to my question.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
