? about vacuum leak detection smoke test
Old Jul 7, 2014 | 07:19 PM
innzane's Avatar
Default ? about vacuum leak detection smoke test
I did smoke test on my 3.0 today, this time I connected thru the brake booster inlet on manifold top. Where the quick connect deal is.
I found some smoke escaping thru the other quick connect on manifold top near the throttle body.
So my question is, is this normal? I do not know, possible the connection may seal under a vacuum and leak under pressure.
Old Jul 8, 2014 | 06:03 AM
Paulc732's Avatar
innzane,
What you could try is start the engine get a friend who smokes to blow smoke and see if it gets pulled in where you think the leak is.
cigars work best i have found.
Another way to test is get a can of throttle body cleaner spray it on the suspected area and see if the tone of the engine changes indicating the vapors are being pulled in. Be very careful as its highly flammable best done when the engine is cold.
stay safe..
Old Jul 8, 2014 | 07:34 AM
Thermo's Avatar
Veteran: Navy
What Paul said. If in doubt, see if there is another way to test.
Old Jul 8, 2014 | 08:32 AM
Paulc732's Avatar
Old Jul 8, 2014 | 04:56 PM
innzane's Avatar
I have sprayed 2 cans all over the motor recently looking for the/if a leak.
Never got it to change tone unless I sprayed it into the air inlet.
But I will try both methods mentioned on this spot again, since it is the most suspect spot I have seen. Maybe even pour some seafoam on it and watch for smoke out the exhaust.
Thanks for the input.
Old Jul 8, 2014 | 05:24 PM
Paulc732's Avatar
Is your check engine light on?
if so could you post the codes.
Old Jul 9, 2014 | 05:09 PM
innzane's Avatar
I am working on a P0174 code. That is all that shows besides the P1000.
Started with the cruise not available message, evolved to that and the CEL over 7-8 weeks time.
Old Jul 10, 2014 | 09:02 AM
Paulc732's Avatar
Innzane,
I had the cruise not available message also turned out my tranny fluid was low.
also had a few other problems and strange codes being thrown by the computer
this actually tuned out to be a weak battery, worth checking these out.
The strangest problem I had was the S button by the J gate would only work sometimes New battery now no problem go figure.
Old Jul 11, 2014 | 02:53 PM
innzane's Avatar
Well I will certainly check my tranny fluid.
And I do have a lil white powder showing on a terminal so I will clean it also.
Thanks again for your input.
clubairth1
30
Sep 3, 2025 04:38 PM
Bcrary3
Feb 21, 2023 04:29 AM
Russ Graber
Feb 23, 2019 11:59 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
Saturbo
Sep 8, 2015 07:35 PM
