Body Code OBD II B1175
Old Apr 15, 2009 | 06:30 PM
mohrd's Avatar
Perhaps post in the Tech Help section in case Techs aren't looking at X-Type today. My AllData starts B codes @ 1200 so I'm no help.
Old Apr 16, 2009 | 09:01 AM
JagXV6's Avatar
Bad news is you need a new LR outer CV joint! The sensors don't go bad. There is a speed sensor ring that corrodes, breaks, and no longer works wit the sensor. Only way to fix it is to replace the outer CV joint $175 or the whole alxe, about $870. (Plus labor if you do not do it yourself.) I went through this (as have many others) last fall. I replaced the outer CV joint myself.
https://www.jaguarforums.com/forum/s...ighlight=c1175
Check that link for all fun details!
Old Apr 20, 2009 | 06:35 PM
JagXV6's Avatar
Well please make sure it is in fact the wheel sensor ring that is bad B4 you go and do it.
That is the common failure--but it could be a broken sensor or wire, but not likely. You can look through a hole in the back where the axle goes through--the ring will be split and may be totally missing. I'd think you would have the speedo problem like I did if it was totally missing.
Glad my post was helpful--I got lots of help from the others here and am only too happy to be giving some back!
Jpav27
Jul 31, 2022 06:43 AM
philwarner
25
Jun 26, 2021 05:43 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
mrplow58
Sep 9, 2015 11:27 AM
