Own a Jaguar 2004 X-Type with 95,000 miles and need an ABS Module Engine Light
Old Sep 10, 2013 | 03:04 AM
lreedyjones's Avatar
Default Own a Jaguar 2004 X-Type with 95,000 miles and need an ABS Module Engine Light
My Jaguar X-Type has recently been popping up with sensor codes. I'vd had it run and For the most part they say the ABS module needs to be replaced. I have a local mechanic that can fix it but I don't want to spend thousands to do that since it isn't essential except for in the winter time and certain weather conditions.
Any suggestions on how and where to start to purchase an ABS module? I have a mechanic who could do the work. Any suggestions would be greatly appreciated.
Some other codes after being run are
C1145 - Wheel speed
P1260 - Security Input
P1582 - Flight Recorder is stored
P1629 - Gen. Front Right Tire Failure
P1632 - Gen. Charge System Failure
P0706 - Trans Range sensor circuit
Old Sep 10, 2013 | 06:14 AM
Thermo's Avatar
Veteran: Navy
Ireedy, I would first start with looking at the wheel speed sensor. That is the more likely cause of what you are seeing than the ABS module. But then, with the array of codes that you are getting, I would have the battery looked at before anything else and see what the condition of the battery is. Having a battery that is weak will cause the computers to toss strange codes and give you the symptoms that you are seeing. The price of a battery is much less than that of an ABS module.
Old Sep 10, 2013 | 11:20 AM
Default Thank you for your response
Thank you! I have several other C codes I think as well. I took it to three different shops even O'Reilly's. I'll have to dig those up.
rsmartin
39
Nov 12, 2021 01:09 AM
Jimscriv
Nov 4, 2015 02:18 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
Terencex
Aug 26, 2015 08:47 AM
divingmom
Aug 25, 2015 07:54 PM
