Trouble With Locks?
Old Apr 1, 2015 | 05:51 AM
Stanvocal1's Avatar
Cool Trouble With Locks?
I wonder can my fellow Jaguar drivers be of some assistance - I have an X-TYPE 2.5L AWD /2007' Up until the other day I've never had any problems with her(my Jag is called LOLA), but now whilst she will lock with the key fob, she will not open with the fob - instead I have to manually unlock the driver's door, put the key in the ignition, give it a quarter turn till the dashboard lights come on and the alarm is disarmed, then switch it off again, take the key out of the ignition, put the key back in the driver's door, and give it a turn to unlock the other three doors and the trunk. Has any other owners encountered this problem and if so, what has caused it? - what do I need to do to cure it?
Old Apr 1, 2015 | 02:02 PM
FollowMe's Avatar
Am i right in thinking that the central locking key fob will not unlock the car? If so it is exactly what happened to mine. Chances are that you will need a new rubber button. Under each button is a small rubber nipple, this nipple pushes down onto the microchip, if this is warn away the connection will be lost. I had this problem and replaced it for £4 on ebay. It works like a charm now.
4BNT Remote Flip Key Fob Rubber Replacement Shell Pad for Jaguar s x XJ XK Type | eBay
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
kevinl
Sep 24, 2015 08:25 PM
