03 x type will crank but wont start, help
Old Jun 14, 2015 | 08:13 PM
sawduster's Avatar
95xtype3.0,
It sounds like you may have confused the computer. I know with my Volvo, I recently worked through some difficult electrical/computer problems, and each time I "fixed" it I would disconnect the positive and negative terminals from the battery and connect them both to ground for about ten minutes, and then reconnect it. This would re-initialize the system to some degree. You could try that. Otherwise, you may have to get the ECU reflashed, which would have to be done by the dealer. But hopefully other forum members might have more ideas that would avoid the dealership visit.
Old Jun 15, 2015 | 04:30 AM
95xtype3.0's Avatar
Thanks for that info, Do the two warnings that come up on the dash, that is, gear box fault, and Pecus error E point us to anything ?
Old Jun 15, 2015 | 07:47 AM
clifton94's Avatar
Check to see what fuel was put in the car if the last place was a fuel garage the other faults may come up as the battery gets a little flat with turning the engine over you would not believe how many people come in my old garage and have done this with fuel
Old Jun 15, 2015 | 11:15 AM
95xtype3.0's Avatar
Hi clifton94, my wife isn,t blonde, LOL, but maybe she put diesel in it by mistake.
I,ll pull the fuel cap and see if I can smell it.
Any idea what the 2 warnings are trying to tell us ?
Old Jun 15, 2015 | 08:00 PM
95xtype3.0's Avatar
Another update on the Jag.
While cranking it over, it,s blowing air out the two front snorkels, that are suppose to be air inlets.
Can a timing chain be messed up on a car that only has 30 thousand miles on it ?
Or does anyone else have any ideas on what might be going on ?
Where,s that THERMO guy, when you need him ? LOL
Old Jun 16, 2015 | 04:12 AM
clifton94's Avatar
Do a compression test
Old Jun 16, 2015 | 04:26 AM
95xtype3.0's Avatar
Good morning Clifton, Thanks for the info. I,ll do that this evening when I get home from work. Cheers, Guido
Old Apr 22, 2017 | 12:18 PM
  #28
Soleil One's Avatar
Default Having
Originally Posted by jamlaw125
First off, thanx for all your help, i feel like i know alittle more about my jaguar. I feel silly, since my used x type came with no manual. I assumed the fuse box was the one I located in the engine compartment. Until yesterday, I did not know there was one under the dash by the driver's side. Needless to say, after your directions on how to get there, I found the fuse, and sure enough, it was blown. I replaced it, and it turned on. What a goof, if it wasn't so sad, so much time and money spent, i would be laughing out loud. Anyway, thank you for you all's help. When i first had this problem, i didn't know where to look until I found this forum. Good day, from south Texas, James.
Having same issue... checking these tread suggestions today! Thank you
stanjag
Dec 29, 2024 08:26 PM
Drew2006
Nov 24, 2015 11:14 AM
1964Daimler
Sep 2, 2015 11:41 PM
Rusty1952
Sep 1, 2015 05:45 AM
cheaperts
Aug 30, 2015 06:48 PM
