03 Xtype windows fogging up
Old Dec 27, 2011 | 11:44 AM
woodyjrj's Avatar
Default 03 Xtype windows fogging up
I am having problems with my 03 x type whm ever the temperature drops below freezing the windows start foggging up. I Have a hard time trying to keep them clear.
Old Dec 27, 2011 | 01:28 PM
BlackX300VDP's Avatar
Might want to check the recirc door is not stuck closed. Raise the hood, remove the retainers on the plastic cowl panel at the base of the windshield. lift up on the panel and you will see the pollen filter. remove the filter and you should then see the recirc door. use a screw driver and push it up and back. It spins on an axis so up and back should work. Reinstall the removed components and test the system. Don't touch the recirc button as the same thing will happen. The recirc motor tends to strip the gear on the recirc door and it will get stuck closed, causing the misting of the windows. Also, make sure the A/C is fully charged. Make sure the pollen filter box is not clogged with leaves and debris.
Old Dec 27, 2011 | 07:57 PM
schuette24's Avatar
Same thing happened to my 2002 x type. recirc flap wore out on the actuator shaft. Took the actuator off and put some good quality 3M epoxy on the shaft and put it all back together. Problem solved.
Old Dec 28, 2011 | 05:15 AM
woodyjrj's Avatar
Thanks I will try it tommorrow if the weather cooperates
Old Jan 31, 2012 | 07:01 PM
aiko670's Avatar
I've been having the same problem and wish I read this before I changed the cabin filter today. Looks like I'll be taking it apart again tomorrow....
Old Feb 2, 2012 | 11:02 AM
xjrguy's Avatar
Here's the bulletin Jag put out about this condition. Shows how to index the motor so it will have the door in the right positions.
Cheers,
File Type: pdf
Old Feb 2, 2012 | 10:43 PM
aiko670's Avatar
Cheers,
Awesome, thank you!
Old Feb 17, 2012 | 02:13 PM
Fee XType 2.5 V6 Sport's Avatar
Cheers,
Many thanks
Thats one of the minor niggles with my new to me jag sorted then
I`ll get my other half to change the pollen filter at same time me thinks
Search and yee shall find
fiona
NS2000XKR
Jan 1, 2017 10:41 AM
Finbarr1975
Oct 4, 2015 05:32 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
blackenedindustries
Sep 30, 2015 10:17 AM
