04 xtype 2.0 diesel PAS groans/wines, another pump fitted tonight, still groaning
Old Nov 12, 2014 | 04:54 PM
mayweather's Avatar
Default 04 xtype 2.0 diesel PAS groans/wines, another pump fitted tonight, still groaning
Hi chaps,
I ran my fluid low in my Powersteering pump, when refilled there was a slight groan present and after several months, it got so loud, that you were even hearing it driving in a straight line at low speed. Its loud enough that those walking the street stop and stare.
Anyway, I guessed the pump was goosed.
I got another pump and had it fitted tonight, for the first 5 minutes the car drove perfect, no groans and all of a sudden it came back, growning and whinning.
What is this? I need help ASAP as I need the car for going on holiday on tuesday and my other half will kill me if she has to wear ear plugs!!
thanks
Old Nov 12, 2014 | 05:14 PM
Welcome to the forum mayweather,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Nov 13, 2014 | 03:19 PM
astromorg's Avatar
This was a common problem some time back, but I haven't noticed any other recent reports of it until yours! The original solution from Jaguar was to use a special additive in the fluid, but whether dealers still stock it in Ireland, I don't know! Try them!
You said you topped up a low level just before it all started - what fluid did you use? Should be Dexron 111, readily available at Halford's etc. If that's not what you used it would be sensible to drain it and start again!
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Apr 5, 2020 07:40 PM
ccfulton
Sep 20, 2015 05:15 PM
1LowCat
Sep 14, 2015 07:51 PM
deanh
Sep 6, 2015 08:20 PM
