05 x type vdp auto lights/sonrrof issue. First jag ever
Old Mar 9, 2010 | 05:33 AM
Edotyelloh's Avatar
Default 05 x type vdp auto lights/sonrrof issue. First jag ever
The auto lamps dont seem to be working. I have to turn them on/off manually. My manual is on the way. is there something I need to do? or is there a fuse somewhere that may need checking. Also the sunroof auto open doesnt work. I'm pressing the back button but theres no response. I have to operate it from the close button Is this normal?
Old Mar 9, 2010 | 08:24 AM
Alfadude's Avatar
Are you sure you have the switch in the correct position for the lights? Not having a manual might be the cause of your problem (actually when I first got my car the manual explanation of the lights confused me a bit). It should be in pointing to the light bulb icon with the "A" in the middle. If you have it pointed at the icon of the headlight with the rays pointing down at an angle you will have to turn that off when you stop the car.
As for the sunroof, to open it fully you should be pushing on the arrow pointing to the rear of the car. To close it hit the arrow pointing to the front of the car. That front arrow also controls just popping the roof open a little bit at an angle. Hope that helps.
Hope that helps.
Old Mar 9, 2010 | 04:39 PM
Edotyelloh's Avatar
Default 05 xtype auto lights
Thanks for the reply. That is the setting I have it on. Ponting to the "A", the setting to the far right. Is it controlled by a fuse? Mabye thats the problem.
Old Mar 10, 2010 | 04:43 PM
Edotyelloh's Avatar
Default AUTO LIGHTS and SUNROOF WORKING!!!
Fixed loose wire in mirror, Auto lights working. Reset sunroof per thread I found here. Everything works.
stanjag
Dec 29, 2024 08:26 PM
ClassiXtype
Oct 22, 2023 05:29 AM
h4wk
Nov 27, 2015 05:10 PM
Jandreu
Aug 29, 2015 07:31 PM
pnwrs2000
Aug 28, 2015 09:31 AM
