07 325i vs Jaguar X Type 3.0 AWD
Old Jun 2, 2013 | 07:05 PM
oldpunk's Avatar
Originally Posted by Syed Muhmmad Hussain Shah
Guys how about the leg space, i have heard it is even less than toyota corolla?
I'm 6'2", and I have a ton of leg room, more than enough. Probably one of the most comfortable cars I've owned. Don't know how it compares to the Corolla, I wouldn't be caught dead in one of those.
Old Jun 2, 2013 | 11:11 PM
Aonsaithya's Avatar
Do you mean the front or rear leg room? I've no issues in the front, but have never sat in the back. They did shorten the Mondeo platform to make the X-Type so that it would have less rear leg room than the S-Type, for obvious market segmentation reasons.
Old Jun 11, 2013 | 09:34 AM
Syed Muhmmad Hussain Shah's Avatar
Ok pulled the trigger and now I am a proud owner of a fantastic Jaguarauto X-type 3.0. Now i need your help in other ways.
1. Is there anyway to make this car faster. The car seems less than the advertised 232 hp.
2. The lack of MP3, DVD playback and navigation is killing me. What are my options
Old Jun 11, 2013 | 04:35 PM
Aonsaithya's Avatar
1. If you suspect it is down on power, you might take it to a rolling road (just make sure it's an AWD compatible one)? There is no cheap way to increase the power of the engine, and even if there was, the transfer case is a weak link in the drivetrain and would require some sort of improvement and to my knowledge nobody has attempted such before.
I must ask, how do you drive the car? I've the 2.5 manual, and it's certainly quick enough for me (I rarely exceed 3000 rpm). I drive in a fairly civilized manner and usually go from 0 to 60mph in maybe 30 to 35 seconds. Do keep in mind that constant hard launches on any AWD car can ruin the drivetrain fairly quickly, if that is your fancy.
2. MP3 compatibility is available through Jaguar's ACM (Audio Connectivity Module), but it's quite expensive (300USD or more + installation). OEM satnav can be retrofitted but it's a lot of work and the system itself is as old as Windows XP so it might not be worthwhile. I've no idea on DVD playback, can't imagine why anyone would need that in a car. Do you watch movies on parking lots?
Most cost-efficient and versatile solution would be some 2-DIN aftermarket headunit, but not all fit. There are several threads about choosing & fitting such on the forum already.
Old Jun 12, 2013 | 11:26 AM
Ok so today i discovered that i have a cd changer in the boot. Isn't there a way to replace the cd changer with auxilary input . I think it should be pretty straight forward?
Old Jun 12, 2013 | 12:52 PM
Aonsaithya's Avatar
It's not straight forward. The car audio system thingy communicates over optic cables, to my knowledge there isn't anything you can hook to that aside from the Jaguar ACM.
If you have a cassette player head unit, then see this:
How-To: DIY headunit hack for AUX-IN (on tape deck).
I'm going to do that as soon as possible too. Not sure if the same trick works with the CD head unit (not the changer), if the same Sony chip is used there as well.
EastFalk
Aug 29, 2015 08:22 PM
hawianjim
Aug 29, 2015 07:23 PM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
