2.5 V6 X Type Oxygen sensor fault
Old Jan 23, 2009 | 01:33 PM
Real_Tech's Avatar
Default RE: 2.5 V6 X Type Oxygen sensor fault
Code p1646 bank 1 sensor 1 o2 sensor control malfunction. Bank 1 is the rear bank and sensor 1 is the upstream sensor which you can see if you look between the engine inlet manifold and the brake booster(LHD). It is screwed into the manifold and has the grey connector next to the booster. You can check power to the heater on the white with green stripe wire. Any other testing will require a scan tool with datalogging capabilities. There were some VINs around your year that had their wires for that sensor twisted up by a faulty tool in the factory but you should be able to see that sort of damage easily.
Old Jan 26, 2009 | 12:23 PM
Real_Tech's Avatar
I'm looking at the code book for X-type right now as it was still open from the post on Friday and P1646 is listed as bank 1 sensor 1, P1647 is listed as bank 2 sensor 1.
Again, i would look at the rear bank upstream sensor heater circuit or fuse. It's the one described in my original post.
Old Jul 12, 2009 | 12:55 PM
perezrp101's Avatar
Default where is the bank one catalystic converter located
looks like i need a new one is this one on the front or back and where is the cheapest place to buy one
Paora
Feb 4, 2021 12:36 AM
Poet
Oct 6, 2015 09:40 PM
Joshua
Sep 24, 2015 07:37 AM
CJagB
Sep 19, 2015 05:00 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
