2 problems, cigarette lighter does not work, remote entry doesn't work half the time.
Old Sep 4, 2009 | 12:58 PM
H20boy's Avatar
my blue friend, glad to see the lighter was an easy fuse fix. That's taken care of.
Your other problems will be best explored by separating your issues and I suggest, posting up new threads on each issue. Give examples, symptoms, as clear and as detailed as you can so others can help you w/o mudding the thread w/ multiple issues. know what I mean?
For instance, based on the limited information above, i'd say (1) need a new battery on your key fob and (2) you've got a wheel out of balance, or if severe, a damaged rim from a pothole most likely or curb encounter. Either may or may not be your root cause, but off the cuff those are my observations. More information from you may change those...but only you can give it to us.
Also, if you have time, it is tradition that new members go to the new member area and introduce themselves and their car. Good luck.
Old Sep 7, 2009 | 12:05 PM
Teck4Jag's Avatar
remote could be a batt or the fob its self i have a few new remotes if you are in need of one and programing them is very easy
pm me
Old Jul 14, 2016 | 04:37 PM
jarrod_9427's Avatar
Can anyone by chance tell me what fuse number is the cigarette lighter? I have an 04.
It's not F68 like the 03's, I don't even see a 68 anywhere.
Old Sep 20, 2016 | 09:44 PM
Thang Nguyen's Avatar
Blue! How many key fob do you have, use other one see how it work? some time one fob being used too much, the contact inside the buttons won out make it work half @*#. It's happen with my fob too. If you run on the highway reaching 65 the car shake, the wheels need balance.
Old Jun 1, 2018 | 02:25 PM
Jag4's Avatar
Originally Posted by H20boy
Bad remote, i'd say (1) .... (2) you've got a wheel out of balance, or if severe, a damaged rim from a pothole most likely or curb encounter.. <snipz>.
How is the remote start function affected by a bad wheel?
Old Jun 1, 2018 | 05:23 PM
Dell Gailey's Avatar
@jarrod #52
Jaguar X-Type Fuse Box Diagram » Fuse Diagram
Old Jun 1, 2018 | 05:32 PM
Robman25's Avatar
He has two problems.
Bent or out of balance front wheel
Remote entry problem with the key fob.
Both possible easy fixes.
Old Mar 28, 2019 | 04:51 PM
annamiata's Avatar
I would just shell out $150.00 to buy a reader that specific for Jaguar. I have the icarsoft i930 and it paid for itself many times over the year with all the detected priority Jaguar code for ABS, Airbag, Transmission, AC system, and Air suspension. I currently own three low miles X-300, S-Type, and X358. I930 works on all three Jaguars.
Old Mar 29, 2019 | 03:49 AM
DAVESPACEBAT's Avatar
With reference to your key fob problem. If you look at the keyhole on the steering column, you will see a small metal shutter that is displaced when you insert the key. It is spring loaded and retracts when the key is withdrawn. If it is sometimes stuck in the open position, it will disable the remote control function.
99.4% Sure this is your problem. Easy to check.
Try a very small amount of oil or some dry film lubricant. Obviously, don't spray oil in there, because of electrical connections.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
johanasu
Sep 3, 2015 12:39 PM
tonydbaker
Aug 30, 2015 11:02 PM
Jandreu
Aug 29, 2015 07:31 PM
