2002 X-Type 2.5
Old Feb 26, 2020 | 12:48 PM
Dean Winchester's Avatar
Default 2002 X-Type 2.5
Ay what's up. I got a 02 xtype 2.5 . And wanna know what spark plugs and wires should I get for good performance
Old Feb 26, 2020 | 03:00 PM
S-Type Owner's Avatar
Welcome. Your engine is equipped with individual coil-packs at each cylinder and does not use conventional spark plug leads like an American engine. Here is a Youtube video that shows you the entire spark plug change process:
Old Feb 26, 2020 | 05:05 PM
As you've already posted another Intro thread, I've moved your question from New Member Area - Intro a MUST to X-Type forum. This is the place to post technical questions about your model.
Old Feb 27, 2020 | 07:17 AM
https://www.youtube.com/watch?v=G8tFsVgyPow
Thanks man. Appreciate the video. What specific type of ngk spark plugs to buy. They have 3 or 4 different types.?
Old Feb 27, 2020 | 08:25 AM
Thermo's Avatar
Veteran: Navy
Dean, when it comes to spark plugs for the X-Type, remember KISS (Keep It Simple Stupid). Yes, there are dual spark, split spark, multi-spark, etc plugs out there. We have found, that if anything, these specialty plugs hurt the car more than they help. Stick with a good single elctrode platinum (some places may even call them double platinum) plugs and you will be good. If you stick with Champion, NGK, or Bosch, you won't have issues. Having a valve cover gasket set may not be a bad idea either since you will be into things hard enough that if you see oil in the plug wells, a few more bolts, you will be ready to replace the valve cover gasket. If you do the valve cover gasket, remember, tighter is not better. Even torque on all the bolts is key and it only needs to be enough to start squishing the gasket. Tightening till the gasket starts to squish out the sides will most likely lead to many problems.
Old Feb 27, 2020 | 07:21 PM
If I get NGK Spark Plugs. Do I need to get NGK Coils 2. Or can I get a different brand of Coils like Delphi.?
Old Feb 27, 2020 | 08:22 PM
Thermo's Avatar
Veteran: Navy
Dean, no need to match the plug to the coils and vice versa. They are all generic parts. I would say to stick with the same brand of coils if at all possible as there might be slight differences there, but even then, that would be minimal and probably not noticable (but may see a slight different color on a plug from it running hotter or colder based on the different voltage).
Old Feb 28, 2020 | 10:06 AM
On the issue of coils, Delphi (or other OEM quality coil packs) are good. Best to avoid the "no-name" Chinese units sold on eBay and other places. Way to much work changing the plugs and then finding a bad coil=pack under the intake...
Terry007
Aug 3, 2017 04:24 AM
jaguarcat
Jul 8, 2014 05:21 AM
bensico
May 10, 2012 02:04 AM
kgrosse
Aug 2, 2011 08:47 PM
BugDoc
Jan 26, 2009 11:06 PM
