2002 x type heat turns cold
Old Dec 14, 2012 | 03:16 PM
ericl007's Avatar
Default 2002 x type heat turns cold
Hi All, I wonder if you can help?
I have a 2002 x type. when the car is all warmed up the temperature of the fanned heat becomes cold at idle & heats right up when rpm are at 1,000 or above. the fan speed is constant, the temperature of the air just drops. the radiator fluid is where it should be...
Old Dec 14, 2012 | 03:37 PM
Thermo's Avatar
Veteran: Navy
eric, first off, welcome to the Forums. You will find lots of very useful information here. So, sit back, grab a cup of joe and go from there. But, we do ask that you do stop by the "New Member" section and tell us a little bit about yourself. We strive to be a little bit different and get to know each other. This also gives you a chance to see who the movers and shakers are around here.
From what you are describing, your problem is the water pump is starting to go and you are loosing a lot of the pressure it builds when the RPMs are raised. Replacing the water pump is easy to do. If you need help with that, let us know.
stanjag
Dec 29, 2024 08:26 PM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
