2003 2.5 whistling/squeal from fuel line/ fuel rail
Old Nov 11, 2018 | 04:30 PM
Mike Badyna's Avatar
Default 2003 2.5 whistling/squeal from fuel line/ fuel rail
Replaced plugs and coils, plenum gaskets, brake vacuum line. No codes any more. Loud squealing/ whistling from fuel rail. Sounds like it's coming from the pressure switch block. Can feel the fuel line vibrating and squealing changes when line is wiggled or pressing on fuel rail. Any ideas?
Old Nov 11, 2018 | 09:51 PM
iownme's Avatar
sounds like something wasnt fastened correctly when rebuilding or a vacuum line isnt replaced correctly.
did u remember to replace the rubber vacuum fitting on the back of the intake manifold?
Old Nov 12, 2018 | 10:32 AM
iownme's Avatar
also check behind the fuel pressure sensor to make sure the line i just mentioned is connected to the back of that sensor
Steve A Bracey
Jan 22, 2017 04:57 AM
Jen & Neil
Jan 14, 2017 11:55 AM
brgjag
Nov 21, 2014 04:32 PM
Jagxjs
General Tech Help
Dec 17, 2012 05:06 AM
martynw
Jun 1, 2011 07:25 PM
