2003 jag x type engine light on
Old Aug 14, 2012 | 06:39 PM
shaunsxtype's Avatar
Default 2003 jag x type engine light on
Hello, my engine light & dsc default sometimes cruise control not availabe is on. Have codes. what does b1145 & b1155 mean?
Old Aug 14, 2012 | 08:53 PM
Thermo's Avatar
Veteran: Navy
Shaun, not to question the codes you have, but are you sure that they are "B" codes, not "C" codes. If they are C codes, then you have an issue with both of your front wheel speed sensors. Normally the B codes are reserved for body components where C codes are reserved for chassis components. Granted, depending on what version of software you have or the version of reader you are using, it may transpose the B and C back and forth.
Not to ask a silly question, but did you have someone recently replace both of your front wheel bearings? The other possibility is you ran over something and damaged a wiring harness (assuming both occurred at the same time).
Old Aug 15, 2012 | 09:01 AM
Thanks for replying, actually they replaced the left front wheel bearing after I was complaining about the driver side riding very rough. I just purchased the car about two weeks ago & I'm pretty sure I didn't run over anything. I got the codes from a Autozone worker. Should I be concern?
stanjag
Dec 29, 2024 08:26 PM
gene1
Aug 27, 2015 08:56 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Terrance Williams
Aug 26, 2015 11:50 AM
