2003 X-type 2.5, ABS or Master Cylinder?
Old Jul 30, 2014 | 12:38 PM
ChirownJag's Avatar
Default 2003 X-type 2.5, ABS or Master Cylinder?
My Cat has developed an issue where the ABS is kicking in at low speeds. At first I thought it may be a sensor issue but no codes are logged.
I had two different certified Jaguar techs check the sensors, brakes, bearings, calipers, and related gear but they found no mechanical issues. The only thing out of place is the drivers side brake pads are wearing down ten times faster than the passenger side pads.
That leads me to believe it is either an issue with the ABS Valve body or the master cylinder.
Does anybody have a way to determine if it is one or the other? Am I even on the right track with this thought process?
Old Jul 30, 2014 | 01:20 PM
Paulc732's Avatar
ChirownJag.
Do you have traction control?
Old Jul 30, 2014 | 02:58 PM
ChirownJag's Avatar
Paul,
I just downloaded the Owners Manual and I see an option to turn DSC off but no way to indicate if it has traction control other than a fault lite. By the way mine does not have DSC from appearances. No button on center console.
Old Jul 31, 2014 | 07:18 AM
alan924's Avatar
If you have DSC you also have traction control. No DSC, no traction control on an AWD car.
Old Jul 31, 2014 | 09:13 AM
ChirownJag's Avatar
Thanks . I just confirmed that as well. So does anybody have any ideas?
Old Jul 31, 2014 | 09:38 AM
Paulc732's Avatar
first off i would change your break fluid.
lets make sure there is no dirt in there acting like a check valve.
also a little silicon grease on the guide pins of your calipers will help stop them binding (front driver side)
Shawn Svacha
Nov 4, 2019 02:47 PM
Greg Reed
Sep 11, 2015 08:41 PM
Darren Schermuly
Sep 11, 2015 07:55 PM
edtexas
Sep 5, 2015 10:49 AM
laserguy
Sep 3, 2015 02:02 PM
