2003 X type 3.0 ltr V6 smoking on startaup
Old Jun 28, 2018 | 01:48 AM
thylacine's Avatar
Default 2003 X type 3.0 ltr V6 smoking on startaup
2003 Xtype 3.0 ltr V6 120,000 klm smokes bad on start up sometimes intermittent any time in the day. but mostly of a morning I have oil in the intake hose at the back of the aircleaner going to the engine have cleaned that and new air filament but still doing it goes great on the road no smoke at all
any thoughts
Old Jun 28, 2018 | 07:30 AM
avern1's Avatar
The only thing I can think of right off hand is it is possible that your PCV valve may be bad. It is the plastic piece connected to the hose on the front camshaft cover. They are inexpensive and easy to replace.
Old Jun 28, 2018 | 10:02 AM
dwclapp's Avatar
+1 to a bad PCV valve. It's normal to find a thin film of engine oil inside the PCV hose and intake manifold. But a bad PCV valve can allow excess oil to escape the crankcase.
After replacing the PCV valve, the smoky exhaust may persist a little longer, until residual oil is sucked from the intake manifold, into the engine and burned.
This thread points to the correct PCV valve for our X-Types: https://www.jaguarforums.com/forum/x...-valve-202731/
Old Jun 28, 2018 | 02:22 PM
Thermo's Avatar
Veteran: Navy
thylacine, is the smoke white, black, or gray/blue? White smoke would imply a coolant leak. Black smoke would imply that your fuel system is dumping too much fuel into the system and it is getting blown out the tail pipe. If you are getting a gray/blue smoke, then that would be oil. IT is possible that your PCV valve is bad and would be a good first check/replacement as it is easy to do and cheap. After that, you are most likely looking at a bad valve guide. As for which one it is, that is where a compression test would tell you that.
celsus
Sep 7, 2017 08:27 AM
koolmanpete
UK & Eire
Jun 7, 2013 06:45 PM
udnyjaguar
Jun 22, 2012 06:05 PM
bbexotics
Sep 2, 2007 09:53 PM
