2003 xtype oil pressure sensor
Old Jan 29, 2017 | 10:14 PM
pennykaye's Avatar
Default 2003 xtype oil pressure sensor
Where is the oil pressure sensor located on a 2003 Jaguar xtype 2.5?
Old Jan 30, 2017 | 06:40 AM
swingwing's Avatar
This from my Haynes manual: "The oil pressure and temperature switches are located on the front of the cylinder block, next to the oil filter. The upper switch is for pressure, whilst the lower one is for temperature."
Steps to access the switch will be similar to doing an oil change, which you might want to do at same time. Jaguar part number for the switch is C2S52255, though it's a standard item you can get at an auto parts store. Here's a YouTube video showing how to replace the switch:
Attached Thumbnails 2003 xtype oil pressure sensor-oil-pressure-switch-c2s52255.jpg
Old Jul 10, 2019 | 12:39 AM
Jag03Xtype's Avatar
Is the oil pressure sensor in the same location for a 03 Xtype 3.0? I step on the gas the light goes off, I release the gas pedal the light goes on. It's regularly oil changed at the dealer. Afraid to drive 30miles out to dealer. Help...anyone...
Old Jul 10, 2019 | 02:53 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...inking-111164/
https://www.jaguarforums.com/forum/s...e-light-36738/
Etc., etc., SEARCH is a marvelous tool
zubizar
Feb 20, 2024 08:18 PM
al_roethlisberger
Feb 7, 2017 07:59 AM
Fosquate
Nov 18, 2016 02:28 PM
Choptank
Aug 9, 2016 07:30 AM
