2004 vs 2005+ TPS and throttle body
Old Jun 14, 2017 | 11:23 PM
Spikepaga's Avatar
Default 2004 vs 2005+ TPS and throttle body
Hello all-
just wondering how much better the 2005+ TPS 's are vs the earlier version. I had unpleasant limp mode problems in my totaled 04 that eventually led me to buy a new throttle body with TPS- which solved the problems- but sadly that car is no more and the 04 throttle body won't fit in my 05. I am tempted to just buy a new throttle body and stick it in the 05, but I can't seem to find many topics where the later TPS model has failed. Plus, if I don't buy a TPS I can get Alpine double din with Apple CarPlay instead.
Old Jun 16, 2017 | 01:12 PM
Spikepaga's Avatar
Anyone got any feedback on this? Are the 2005+ TPS as notorious for failure as the earlier version ?
Old Jun 16, 2017 | 01:28 PM
Alfadude's Avatar
All I can tell you is my own experience. I had a 2005 and when I traded it in it had over 160K on it and never a problem with the throttle position sensor or throttle body. Just my two cents, but it seems kind of extreme to just change that out if you aren't experiencing any problems. I can see your thinking on trying to be pro-active, but that is a good amount of money to spend on something that might never be an issue. I would go for the sound system and roll the dice on this one. Good luck with your new ride when it comes.
Old Jun 16, 2017 | 05:23 PM
JagV8's Avatar
Start with an OBD tool with live data such as an elm327 and check sensors for plausibility then fuel trims. If all OK then leave TPS etc alone.
