2004 X-Type 3.0L- Starts/runs fine then stalls after 3 to20 minutes
Old Mar 24, 2016 | 10:05 PM
phil51's Avatar
Default 2004 X-Type 3.0L- Starts/runs fine then stalls after 3 to20 minutes
An update on my previous post. I have changed all 6 coil packs from generics to name brand ( Delphi), 6 new spark plugs, upper and lower intake gaskets, replaced fuel injector seals/screens, had my ECU checked by a rebuilder who said it tested fine, checked all grounds. Checked for vacuum leaks with acetylene. It starts and runs perfectly and anywhere from 3 minutes up to 30 minutes it will stall out by flooding. It will set codes P0351,P0352,P0354,P0356 indicating misfires on cylinders 1,2,4,and 6. Car will restart and run fine. You can smell gasoline when it stalls. The car will run for long periods of time perfectly and then spontaneously shut down. Car has 82k lady driven miles and is otherwise in excellent shape. Originally from North Carolina. Any help would be greatly appreciated. We're running out of ideas. Thanks, Phil
Old Mar 25, 2016 | 06:24 AM
chiefM's Avatar
Fuel pressure regulator ?
Old Mar 25, 2016 | 01:18 PM
Norcat's Avatar
Crank sensor?
Old Mar 25, 2016 | 08:18 PM
phil51's Avatar
Crankshaft position sensor was replaced. thanks, Phil
bklynchris
Mar 1, 2016 10:42 PM
OMGPirate
Mar 1, 2016 06:38 PM
PJ Reynolds
Feb 28, 2016 05:10 PM
Flyboygus
Feb 27, 2016 05:28 PM
harvest14
Feb 26, 2016 10:43 AM
