2004 x-type blowing ignition fuse
Old Sep 21, 2013 | 04:29 PM
miked126's Avatar
Default 2004 x-type blowing ignition fuse
im lost ,I have an x-type with a 2.5 when I go to start it it keeps blowing the 15 amp ignition fuse.
Old Sep 22, 2013 | 08:13 AM
Thermo's Avatar
Veteran: Navy
Mike, what year X-Type do you have as the wiring changed in early 2004. If you have a 2004 model, then also include the month that it was built (located on the sticker in the driver's door jam area). From there we can get this figured out for you.
The thing that I would try first is switching the starter relay with another one of the same rating. Then see if your problem continues. It is very possible that your relay has failed internally and that is the root of your problems. After that, we will need to do more testing. On a side note, how are you with using a multimeter? That will help me tailor the tests you do to what your skills are.
Old Sep 24, 2013 | 04:53 AM
miked126's Avatar
My car was built 4/04. Where is the starter relay located? Thanks
Thang Nguyen
Oct 12, 2015 01:25 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jagent
Sep 12, 2015 01:40 AM
texaspete
Sep 10, 2015 08:34 AM
avern1
Sep 8, 2015 06:25 PM
