2004 x type will not start
Guest
Posts: n/a
Hi, my 04 x-type 3.0 was ran of the road and now will not start. I had to replace bent control arms both front and back on the right side. the inertia switch was tripped but I reset it. All my fuses are ok. everything inside the car works fine. but noting happens under the hood when you turn the key. I connected my OBDII scanner and it reads "Err" when i try to link to the ECM. anybody know if I can test the computer or reset or reprogram the computer. or maybe I am overlooking a simple ground wire or relay?
thanks for any help.
Guest
Posts: n/a
thanks but reset that already. did notice today that when I disconnect the computer ground under the hood and turn the key the cooling fans come on high. so I think the computer is getting power. but still no response with the scanner.
stanjag
Dec 29, 2024 08:26 PM
1964Daimler
Sep 2, 2015 11:41 PM
Aranon
Sep 1, 2015 01:00 PM
