2L diesel running problems
Old Dec 2, 2022 | 12:28 PM
MCW739's Avatar
Default 2L diesel running problems
I have three different engine running problems which I'm sure are related but am not sure how or what's the cause. The car has 144k on the clock and had new injectors at 138k. There are no codes. I used to run with the egr blanked off but removed the plate when the guy at the fuel injection Co thought that was the cause of problem 1. It seemed to cure it but with the colder weather the problem is back.
Problem 1. At approx 1500rpm on a light throttle, usually in 3rd gear on a slight incline the engine misfires quite severely. Pressing the throttle more stops it.
Problem 2. Occasionally on a hot start the engine either runs on less than 4 cylinders or possibly backwards (if that's possible?).
Problem 3. When starting from cold the engine starts with quite a bang, if it were a petrolengine I'd suspect the ignition timing was too far advanced. After starting though it runs OK.
Old Dec 5, 2022 | 03:51 AM
Cornerz's Avatar
@MCW739 I had all sorts of weird behaviour from my 2.2D when the EGR was failing.
Not impossible that you have multiple issues (although Occam's Razor suggests one more likely) - have you tried disconnecting the EGR plug to see if that at least changes the symptoms (will throw an error eventually, but good for a short term test). My failing EGR didn't give any error messages, but caused all sorts of issues.
Old Dec 5, 2022 | 04:31 AM
MCW739's Avatar
I haven't tried that but will do. - just done a 16 mile trip with the egr unplugged. Unfortunately the misfire at 1500rpm is still there. Engine also took longer to warm up but was smoother and quieter all round.
I can't find any post by 'Occam's Razor', can you let me have a link?
Old Dec 5, 2022 | 06:12 AM
Cornerz's Avatar
Occam's razor is just a principal that broadly states that the explanation requiring the fewest assumptions is usually the correct one. (If you hear hoof beats think horse, not zebra.)
In this case it is generally my assumption that a particular issue on a car is more likely to be caused by one fault, and not multiple faults. Possibly a bad assumption with an old car
Old Dec 5, 2022 | 06:21 AM
astromorg's Avatar
Here's one link (of many) to introduce you to the man.
https://www.britannica.com/topic/Occ...20posit%20more.
William's approach to complex problems is remarkably valuable in many diagnostic situations that he could never have imagined!
Old Dec 5, 2022 | 07:49 AM
MCW739's Avatar
Aah, I see now, pardon my ignorance.
feniks138
Jun 3, 2022 05:59 AM
kingnero
Dec 22, 2019 12:04 PM
Miraine
Jul 6, 2013 02:56 AM
ianfrizell
Feb 9, 2013 09:47 AM
bazzza
Jun 7, 2009 01:14 PM
