53 plate (2003) X Type rear parking sensors
Old Feb 1, 2013 | 07:16 AM
mikep1947's Avatar
Default 53 plate (2003) X Type rear parking sensors
Hi all
rear parking sensors do not work on my x type
When I put key in ignition and switch on I get (about) a 10 sec warning buzz, same when I engage reverse.
Buzzing sound comes from parking aid module.
Reverse lights function ok.
I have checked sensors, all beep (click) like a pod of dolphins, tried a replacement PAM that works ok in different car, does not work in mine!
Went to a car electronics repair shop, they could not find cause of problem, and confirmed all checked parts as above working ok!
Has anyone had the same problem and solved it?
Old Feb 3, 2013 | 05:11 AM
I've moved you tech question from the UK Region section to the X-Type section.
You should get help and advice here from members with the same model.
Old Feb 3, 2013 | 07:17 AM
Thermo's Avatar
Veteran: Navy
Mike, you have done all of the basic checks. Based on what you are describing, it is sounding like you have either a bad wiring harness or the parking aide module has failed. the best advice that I can give you is to take it to a professional that can hook up one of the jaguar dealership computers and let them get in and see what the computer tells them.
I wish I had better news and maybe someone else will chime in here with something else to check. But, what you are describing is something with the return signal and this signal is not something that you can troubleshoot on your own unless you have some expensive equipment.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
ClassiXtype
Oct 22, 2023 05:29 AM
big d
Sep 3, 2015 07:37 PM
tberg
Aug 31, 2015 04:33 PM
