ABS light on and cruise not working
Old Aug 5, 2017 | 12:32 PM
otherman's Avatar
Default ABS light on and cruise not working
Hi
earlier this week my abs light started to show. It doesn't come on right away, but fairly soon after I set off. I noticed today that the cruise control isn't working either. Do these two faults together point at anything in particular?
Old Aug 5, 2017 | 12:55 PM
USarmor's Avatar
Otherman,
Yes they are related. When the ABS is not working the Cruise Control will be disabled.
First thing you need to do is get the codes read on your Jag. Be sure the reader will do ABS/Chassis (C) codes and not just Powertrain codes (P)
Most likely you will get a C1145/C1155/C1165/C1175 unless it is related to the ABS module.
If it is one of the above, then you will know which side is causing the issue. It could be the sensor and/or the speed sensor ring (reluctance ring).
The Jaguar Workshop manual will explain the pin point test you can do to determine if the sensor is faulty.
If it is the speed sensor ... see the discussion at the link below #15 for how to inspect and replace the outer shaft (if your issue is in the rear).
https://www.jaguarforums.com/forum/x...lacement-1982/
Good Luck . . . . Just fixed mine last week!!!
Old Aug 5, 2017 | 12:57 PM
otherman's Avatar
Great, thanks. Trip to the garage then.
Old Aug 7, 2017 | 03:01 PM
Jagisbest's Avatar
Abs faults disable cruise control, i had an intermittant fault on an xk and it was a faulty abs sensor which cost £40 to sort diy but before ypu spend money get the codes read and bear in mind your braking is compromised if your abs has failed
Old Aug 9, 2017 | 01:59 PM
chknhwk's Avatar
Originally Posted by USarmor
Otherman,
USarmor, is there a recommended code reader for the X-Type that we can purchase ourselves? I was checking around on the interwebs because my problem is similar to this and I came across the
iCarsoft i930 iCarsoft i930
, any thoughts on this one? I have also been thinking of getting one of those OBD2 plugin readers with Bluetooth for instant diagnostics. Any help would be appreciated!
Old Aug 10, 2017 | 01:19 AM
Jagisbest's Avatar
The i car soft jag on amazon was the reader i was about to recomend you try using
Old Aug 10, 2017 | 10:41 AM
chknhwk's Avatar
Thank you! I'm torn on whether getting that or getting a cheaper Bluetooth dongle for real time monitoring AND code retrieval...
Old Aug 10, 2017 | 02:27 PM
Jagisbest's Avatar
the blue tooth would be a waste of money as i think they only read engine codes .
Old Aug 10, 2017 | 06:36 PM
chknhwk's Avatar
Ah, good point. Knowing what they are is part of it but being able to clear them is just as important. Thanks!
(Although a lot of AutoZones, etc. will clear them if you show proof or explain how you fixed something...)
Old Aug 12, 2017 | 09:22 PM
Phantum's Avatar
Default Maybe this
Will help your decision on whether to buy or not, I had purchased this icarsoft scanner because the scanner I had would not read the abs codes, it did everything I have asked of it to this point abs, obd, electrical system and battery scan, o2 bank scans, its a great tool, well worth the $120.
comes with usb cables obd cables, manual and a nice little carry case.
And it works on tons of other cars as well, some with more / less functions available.
but overall a great investment.
Old Aug 21, 2017 | 07:37 AM
chknhwk's Avatar
That's awesome! I ordered the BAFX OBDII bluetooth adapter and I am using the Torque app (pro version) and I was able to both read my codes and clear them. Not bad for under $30!
I am getting C1175 and P1111 codes.
Old Aug 21, 2017 | 07:54 AM
USarmor's Avatar
chknhwk,
No worries about the P1111 - that is normal and just means the drive cycle test are complete.
P1175 is the Rear Left Speed sensor. Take a look at my post #2 above for most of the information you will need.
Good Luck!
