Ac delete on 3.0 v6
Old Aug 13, 2022 | 07:06 AM
Jayv6xtype's Avatar
Default Ac delete on 3.0 v6
Hi all looking to do a ac delete(ac pump shat itself) on my 2001 xtype 3.0v6 4x4 sport. Im looking for the correct belt i need to delete the ac out im based in uk so need it in uk measurements please as ive found some belts but unsure which size to buy
Old Aug 13, 2022 | 07:39 AM
Thermo's Avatar
Veteran: Navy
Jay, your best bet will be to get rid of the A/C unit and then fabricate a new idler pulley to go in its place. I am not sure if you have a part of the engine that may stick out between the crankshaft pulley and the idler pulley (the points just before and just after the A/C).
If you think you can do it without making this pulley, then all you need to do is take a string, route it the way that you are going to route the serpentine belt and measure the length. You then have the critical dimension you need. You can then walk into your local auto parts store and they will be able to look up the belt that would be closest to what you need. So, for example, if the factory X-Type belt is 890mm in length, your string may be say 750mm, you simply ask for the 5 rib, 750mm belt. The auto parts store will be able to tell you the nearest belt they can get.
Old Aug 13, 2022 | 07:43 AM
Jayv6xtype's Avatar
Default Shorter belt
Ive tried various motor factors they said the same as you about measuring with string all i need to do is delete the ac out until i sort some money out for a new ac compressor
Jayv6xtype
Aug 13, 2022 07:04 AM
chillyp
Sep 9, 2021 06:52 AM
Simon.h
Nov 13, 2012 03:07 PM
tford
US Northeast
May 31, 2011 11:03 AM
