Air compressor leak!
Old Feb 28, 2017 | 04:01 PM
Harry Peter Rose's Avatar
Unhappy Air compressor leak!
x type 2002 2.5.....repair shop informs me air con compressor leaking requires replacing....
.......around $1,000 estimated {Richmond BC Canada} .
NO SIGN OF ANY LEAK IN MY GARAGE?
any advice?
Old Feb 28, 2017 | 04:28 PM
sov211's Avatar
Do you mean the air conditioning compressor? (You must, as the x-Type has no other compressor - or is your car an XJ with air suspension? That car does have a compressor for the suspension. It REALLY helps if you identify your Jaguar model with every question).
In any case, if it is the AC compressor there will be no sign of a leak in your garage! You *might* be able to see a trace of leakage on the compressor itself. What leaks is a gas, what you might see is traces of the compressor lubricating oil.
The compressor itself can be resealed but it is probably better to replace it if otherwise defective. If it simply is low on the refrigerant charge, it can be regassed (with a dye added to trace the leak).
Old Mar 1, 2017 | 05:11 PM
sov211's Avatar
Ok, you have been given advice, so....?
Old Mar 3, 2017 | 02:45 PM
Thang Nguyen's Avatar
If the shop tell you the A/C compressor is leak, ask them to show you where is the leak, if it leaked at the hoses fitters, you might able to take them off and resealed them yourself, if it leaked on the compressor body, buy a new one online and replace it yourself too,, just jack the car up, it in passenger side in front of engine, remove the serpentine belt, few bolts on compressor and two hoses, this is easiest job on X-Type.
