airbag flashing codes please help
Hi All
Been steadily rebuilding my car after a bump changed the module and airbags etc but still getting a flash code
it flashes once and then 3 times and the engine light stays on
has anyone got an idea what this means please.
i thought i was done but have hit a wall again!
thanks
thanks
apparently it means crash data memory full so not sure if the secondhand airbag module i got was any good or just a reset needed?
anyway the codes are here if it helps anyone else
13 - Crash data memory full
16 - Pass seat weight sensor CAN fault
17 - Pass spatial sensor CAN fault
18 - Pass airbag deactivate lamp circuit fault
19 - Airbag circuit status fault – driver
21 - Airbag circuit status fault – pass
22 - Side Airbag circuit fault – driver
23 - Side Airbag circuit fault – pass
33 - Seat Belt Pretension fault – driver
34 - Seat Belt Pretension fault – pass
42 - Impact sensor circuit fault – front
43 - Impact sensor circuit fault – driver side
44 - Impact sensor circuit fault – pass side
51 - Seat belt switch circuit fault – driver
52 - Seat belt switch circuit fault – pass
53 - Airbag audible warning circuit fault
54 - RCM configuration failure
if anyone can confirm that its a reset job i would be grateful
Johnken
Sep 15, 2015 05:46 PM
