Another lower control arm topic
Old May 30, 2014 | 06:42 PM
Spikepaga's Avatar
Default Another lower control arm topic
Hello guys,
My car has had noises and clunking coming from the front for a while now. A couple of weeks I had the front pads changed and that added a new screeching noise when stoping and turning, so I dropped it of this morning to get as much as possible fixed......
So after two new rotors, sway bar bushings, sway bar end links an alignment, and 700.00 dollars, the car feels 95% better, but still needs the front lower control arms.
I went ahead and bought two new complete arms for 160.00, and was wondering if I can replace those myself....
Any insight would be greatly appreciated !!
Old May 30, 2014 | 08:30 PM
Thermo's Avatar
Veteran: Navy
Spike, fellow members have replaced the lower control arms themselves. The big thing to keep in mind is that you are going to need to drop the lower front subframe down a little bit so you can back the bolt out far enough to get the lower control arm out (the back bolt near the firewall). Not a hard job, but, don't plan on getting the job done in an hour. Plan on something more like a complete afternoon.
Old May 30, 2014 | 09:01 PM
Spikepaga's Avatar
That helps a lot Chris.
I'll just pay to have it done. Complete afternoon sounds like two weekend with my luck.
Jandreu
Jun 30, 2022 03:10 PM
ym37tech
Feb 8, 2016 01:04 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
Harry Dredge
Sep 3, 2015 03:04 AM
