Any Experience with Fuel Gauge not working?!!!
Old Dec 1, 2010 | 10:26 AM
remaricle's Avatar
Default Any Experience with Fuel Gauge not working?!!!
Happy Thanksgiving to all. Hope everyone had a good turkey day!! I had a fuel gauge concern and couldn't seem to find any threads on that subject. Gauge read 1/4 tank, so filled up and when I started the car gauge went to empty and stayed there. Doesn't appear to be a fuse out, however it is hard to see at night. Any ideas?
Old Dec 1, 2010 | 06:31 PM
Thermo's Avatar
Veteran: Navy
remaricle, I have had this problem with another vehicle. It turned out that the level gauge in the tank had failed (shorted to ground). Unfortunately, the only fix is to install a new level sending unit.
Old Dec 2, 2010 | 03:32 PM
remaricle's Avatar
Hey Chris thanks for the response.. funny the gauge did not work for 2 days and then started working again today. Do you have to remove the tank to replace the unit?
Old Dec 2, 2010 | 05:08 PM
Thermo's Avatar
Veteran: Navy
remaricle, you can remove the rear seat and there is an access cover on the passenger side that will allow you to access the passenger side stuff (level sender and 1 of the fuel pumps). Just be careful with the plastic ring on the top of the tank as with the colder weather, it can be a bear to get off and will be fairly brittle. If you can get the car inside a heated garage for an hour or so before hand, that would be ideal.
As for the level gauge working again, sounds like a broken wire inside the sender. I had the same symptoms. I could watch the level come and go.
toronadomike
Jan 22, 2026 10:13 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Russ Graber
Feb 23, 2019 11:59 AM
johnnie ryall
Oct 19, 2015 09:44 PM
