Automatic Lights
Old Jun 12, 2012 | 02:20 PM
dmennis's Avatar
Default Automatic Lights
I have a jaguar xtype without automatic lights and am wondering what else i would need to buy/wire if i buy the headlight switch with the automatic setting?
Any help would be great thanks
Old Jun 12, 2012 | 03:24 PM
Thermo's Avatar
Veteran: Navy
When you say "automatic headlights", are you referring to DRLs or do you mean the auto-on where it turns on all the lights?
The issue is if you have DRLs, then installing the lights that come on when things get dark can not be done. The wiring is physically different between the two and the DRL headlight switch does not have the connections to make the low light feature work.
If you have non-DRL headlights, then you will need to low light headlight switch and also get the associated module to wire in the light sensor.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
