Is it bad control arm bushing? Picture.
Old May 18, 2014 | 08:01 PM
car5car's Avatar
Default Is it bad control arm bushing? Picture.
Is the bushing cracked or it is designed with two"cracks"? Front control arm rear bushing. Do they go bad a lot? Is that pretty common problem? there is suspension knock, which problem is most common for X-type suspension?
Attached Thumbnails Is it bad control arm bushing? Picture.-bushing-lf-control-arm-rear-003.jpg
Old May 18, 2014 | 08:23 PM
ltmax's Avatar
That bushing looks ok, it may be the lower ball joint or the most likely culprit is the sway bar end links.
Old May 21, 2014 | 02:24 PM
Paulc732's Avatar
i would also look at the sway bar bushings bit of a pain to change but that stopped the knocking for me.
Jandreu
Jun 30, 2022 03:10 PM
ym37tech
Feb 8, 2016 01:04 PM
blobthebuider
Sep 10, 2015 04:51 AM
mrplow58
Sep 9, 2015 11:27 AM
